Punch holes
2749.55 In reply to 2749.54
Well I created points for the file. (Much easier than trying the trim) I loaded the points save and load commands from petr. I had a question about its use if petr is looking in.
I was hoping that there was a tolerance setting that would help control the polyline creation. There is a "decimal places" setting and I am not sure how to use this or if it is intended for this result. Could you expound?
With regards to a connector script, the point cloud looks like this:
But from the top, it is this:
If I could connect only points that are .125 apart, the tolerance setting, then this would work.
I suppose it would have to apply to ANY other interest in connecting "points" or even "Segment ends". Kindof like the extend with a Limitation setting. (and also working on points).
Anyway, enough about this now from me. I will try trimming in smaller batches to get the result I am looking for.
Burr
