Punch holes
2749.43 In reply to 2749.38
Hi Burr,
> Can the Isect command place a point where the wire enters and exits the solid?
Yup, the Isect command will generate points where a curve intersects with the surface skin of a solid, so for instance with this curve and solid:
If you select them both and run Construct / Curve / Isect, you will get these 2 points as the result:
> Can I automatically connect 2 points?
It would be possible to make a script that would do this, let me know if you want me to cook one up.
