Hi Michael
Conic curve looks great. I guess an rho value is a little arcane and not fitting the simplicity of MOI so well, but will you be able to adjust the conic curve after creation? For example if you make a loft with conic curves will you be able to update the conic and see the surface update?
I can understand conic surfaces and fillets are more complex to integrate. Attached is a picture of a conic surface between tangent edges (with a spine curve, rho value .7)
This is a really usefull tool. The geometry is light and rho vlaue allows you to adjust the cross section. Also because it cant have inflections it helps create good quality geometry simply which I think fits MOI well.
Will the conic curves be in the next beta? or in V2? I guess the beta stage for V2 is nearly over and its time to earn some well deserved money.
Jamie
p.s good to hear the environment mapping is on the radar
