I've found out some strangeness and an inconvenient feature of the array command.
1)
The Array-Curve command creates the right number of items along the close curve (free-form or polyline), but the objects aren't placed evenly - the first object cover the last one. It only happens when I type the "item count". For typing "distance", there is the identical number of the actual objects and the computed item count.
2)
The Array-Circular command seems not to be well-behaved for vertical or radial step options. Have a look at the next pictures... ( array_circular.3dm)
This is ok....
...it isn't...
It is the same for the radial step option.
How do you feel about it, Michael?
Petr
