>I kind of try to avoid this type of thing where
>there are similar fields, where one is ignored
>if another is filled...
However in the Array-Curve command prompt there are two fields - Item count and Distance - and an applicable is underlined.
So you can choose either that kind of behaviour or this  how you mentioned. Anyway I think it would be useful feature.
>If I understood him correctly, I think that Petr's later
>analysis was a vote for keeping it the way it currently is.
Definitely!
>You Europeans with your commas and decimal points all reversed
>are always causing problems!! :) :) :)
hehe....
Petr
