| Hi Michael,
 I just have an idea how to work with a mini command-line entry more efficiently while using keyboard extensively.
 The heart of the matter is that you will have to add a moi.ini option to suppress an one-letter shortcuts and let each letter keystroke (not number) go to the XYZ coordinate entry box automatically without putting focus first (even while running the command). It means there would be no need to type <Tab> before typing a command name or command alias defined by given name of javascript file.
 At best case scenario the command would be executed not after hitting <Enter> but also after pressing <Space> (there are no commands with spaces in their name and spacebar is significantly wider and has better location than return key when handling a keyboard by single hand).
 Petr
