Could you update moi.idl?
2715.26 In reply to 2715.25
Hi Anis,
> But you need to get MoI SDK before
> it will happen ? Isn it ?
You would need an SDK to do something very completely different from anything currently in MoI, like make a T-splines plugin or complex things like that which do a lot of unique low level processing.
But even without a C++ SDK you can use scripting to create plug-ins right now that work with the existing tools in MoI but package them together in different ways.
There is a lot that can be done with scripting, there are several example plug-ins that you can look at already which are collected on Petr's page here:
http://kyticka.webzdarma.cz/3d/moi/
One reason that scripting works well in MoI is that it is not just something kind of "tacked on" to MoI, it is used for all of MoI's regular functions. For example commands such as the line command, curve command, etc... all have a script component to them.
