joint?
2691.8 In reply to 2691.7
> So why curves generator have the same color (selected
> or not) than the other curves by default?
> It will be not more easy to distinguish them?
I've tried to avoid having too many things of different colors by default - if you don't understand what the colors mean, it can be confusing.
Also too many default colors then becomes incompatible with using a colorizing system as user-choice method of organizing objects.
So there can be some bad effects from doing that.
My best suggestion currently is that you should try and "clean" up your generator curves after you have created a surface from them. They are generally selected after you have created a surface and that is a good time to hide or delete them to get them out of the way.
