Export as LWO to Modo...scale issue???
2686.6 In reply to 2686.5
Hi slayer no problem, I'm glad that it is working for you now!
One thing that may have got things set off wrong is if you happened to use File/Import to bring the STEP file into MoI rather than File/Open.
Import is meant to keep the current model and merge the file you pick into it. So because of this, it does not change whatever units were set in the current model.
But if you use File/Open, the units that were set in the STEP file will become the current units inside of MoI.
