> I don't find it an inconvenience, it sort of follows the natural
> flow of thought, "I want to extrude this string of curves...this
> direction... then I want to unite/subtract it to/from this solid.
Yeah, but what if it could be "I want to extrude this string of curves... this direction ... done".
Then you want to do another one - pick some other curves, right click to repeat the extrude command, pick the distance, and done again.
The way you are mentioning it here, it almost sounds like you're talking about an additional stage to the extrusion? I mean that after you pick the direction/distance, the command would not end and instead it would ask you if you wanted to do a boolean or not?
> What would happen in the case if the curves you picked were not closed ?
No boolean for that case I don't think - it would just behave the same as currently.
