Import point file script (Windows 7)
2638.5 In reply to 2638.3
Hi George - hmmm that is rather odd. Maybe somehow the script library for the "FileSystemObject" which that command uses did not get configured properly on your Windows7 installation.
Try running the following from a command prompt (or Start/run):
regsvr32 scrrun.dll
Another possibility may be if you are running some kind of anti-virus system that may be blocking access to that particular library since it can be considered a security sensitive thing since it gives scripts access to files. You may try temporarily disabling your virus checker or see if there is a way you can configure it to allow a script running inside of MoI.exe to be allowed access.
Please let me know if none of these things help any and I will try to look into it some more.
