Import point file script (Windows 7)
2638.2 In reply to 2638.1
Hi George, it sounds like some of the security mechanisms in Windows 7 is preventing that script from accessing the "FileSystemObject" which is a tool that allows scripts to manipulate files.
If you right-click the icon for running MoI I think there should be a menu that pops up that has something on it like "Run as administrator" - if you use that method to run MoI probably that error will go away, does that seem to work?
Also if you right-click the shortcut and choose "Properties", I think there should be some option to always run as administrator, you may need to set that up if you need to use that script.
