curve array enhancement
2626.34 In reply to 2626.33
> All that can't be easy solved by "Instancing" a volume array /
> curve then replace at the end these volume by the "2 lines"?
No, not if you want things to touch each other exactly.
Making an arrangement where items sort of "tile" to fit in available space is a rather different problem than just regular "instancing".
To make things fit and touch each other, you can't just replace one object with any other object, things need to be of specific sizes.
> Instance of objects is not projected in early Moi version?
I'm not really sure when. Definitely it won't be in v2 though.
