curve array enhancement
2626.1
Currently as far as I can tell it isn't possible to align an objects length (start and end point) along a spline only a single point that will try and rotate as it goes along the path.
in the example I have an upside down V shape that needs to have both end points follow the curve of the oval path but the align tool will only use one of these points so the other will come away from the path as it's mulitplied around. Is it possible that this function could be added at some point?
Rob
