My 2 cents on the styles part:
it's the only part of MoI that for me does not work according to my intuition..
Here are the issues I'm having - some of them will probably be adressed in the next betas or the 2.0.
1. Hidden geometry.
If a layer has some hidden geometry and you select it, the hidden geometry is unhidden. From then on the eye will let you hide/unhide, but not hide the part that was hidden in the last state. I like to hide some geometry (like some edges were two surfaces meet), but with the styles I have to hide them again everytime i fiddle with the layers. Some issue with the types here: if you click on one of them, all the geometry is unhidden.
A hidden geometry style is part of the solution. The annoying thing there is everytime you change something to a hidden layer the geometry shows up instead of disappearing. Then you have to click the eye twice to unhide all and then hide all.
2. Adding a style
You have to select a style first to be able to go into the styles menu. Then if you create a new style the selection of the existing layer is automatically changing to that new style. If would just like to be able to add another style to create new geometry or paste rhino geometry.
3. Changing a style's color
A lot of steps for a very simple operation - but i think that has been mentioned before. Part of the problem is you lose the selected layer along the way and have to reselect it to assign it's color.
My suggestions:
My ideal styles behaviour would be:
1. objects are hidden if you transfer them to a hidden style
2. you have three states of a style: unhidden, hidden and partly hidden, where the 'partly' in the last option is memorised. Same for the Types
3. a style state does not change when selecting the style. When you click it now, everything is selected, the hidden parts as well. And that can't be undone. So if you have a lot of hidden geometry it get's unhidden very easily. Two solution now: hiding everything manually again or going back to the last saved version..
If the style behaviour as it is now will be maintained, would it be possible to add a hidden layer that remains hidden when you throw geometry at it?
I have tried to get my head around the styles, they are a big plus in comparison to the 1.0. I can see the potential of combining styles, types, objects and groups and being able to combine selections. But as it works now, it also has some big drawbacks.
It's still a beta, so I see why of course. Just trying to help out with getting it streamlined, not meaning to rant!
Oh and one more minor thing: i don't get the name styles. In Sketchup you have styles and they are why different. More different from MoI Styles than MoI styles are from Layers. So I think it's cunfusing as a name.
My proposal: call them Slayers. Special Layers. Hell yeah!
