I have another Cplane request, can a CPlane translation be implemented when activated.
I couldn't see any space in the existing command UI for an XYZ value input, the only way I could see it work is to use the main numeric input field for a precise distance translation for XYZ.
BTW, I think I mentioned this before, when positioning the CPlane using construction lines, once done the construction lines hang around, they even come back when you do an undo.
~Danny~ |
