Hi Danny - copy and paste is set up to just literally duplicate objects, it does not attempt to modify the pasted objects in any way, like changing them in orientation or anything like that.
That could be a good idea for something to add in the future though.
In v3 I want to work on adding some various orientation tools to help with placing objects in relation to other pieces.
For v2 though you will need to use the Move, Rotate, or Rotate Axis Transform commands to adjust the orientation of the part to where you need it.
If you need some help with that, if you could post your model I could go through some steps for that.
