Wish: disable num pad UI for meshing
2598.6 In reply to 2598.5
Hi Micha,
> Right, but from time to time the UI pop up again and that worries.
It should never pop up if you are only typing...
If it pops up randomly when you are only typing instead of on a click, then that would be a bug. Are there some steps that you can show me that reproduces that problem?
The only time that it is supposed to pop up is if you clicked on a control with the mouse.
I should be able to add in an option in moi.ini to turn them off, but in general if you want to type in values rather than use the mouse, then like Tony mentions just start typing or push Tab and it will not pop up.
As a bonus you will even have saved an extra action since you won't need to click with the mouse at all then.
