Hi Brian, I guess I don't quite understand what you're complaining about here...
Have you needed to edit the .ini file yourself? If not then what is the problem?
Sometimes I put options in the .ini file to make it possible for advanced users to tune MoI to have some special behavior that helps their specific type of work.
If I didn't do such things like that, the other options available to me are to either tell those advanced users that they are just out of luck, or to jam in a whole bunch of advanced and specialized options directly into the regular UI, which would make MoI more difficult to use for beginners.
So putting things that beginners never need to mess with as a .ini option actually helps make MoI easier for you to use...
Hopefully that may help to explain the reasoning behind this stuff to you a bit more.
