Hi Brian, make sure to include a single Point object along with the objects that you are arraying, it is used as the center point of the scale.
The point can be drawn using Draw curve / More / Point.
The point should be placed at the spot that you want the scaling to happen from, select the point along with your objects when you array them.
See here: http://moi3d.com/forum/index.php?webtag=MOI&msg=275.109
for the original ScaleArray post that has some more details and an example image.
