V2 beta Apr-12-2009 available now
2570.204 In reply to 2570.203
Hi Michael!
1. Re analytic output: (shown below)
If I change section parameters to y (both or one by one) SAT file is not exported at all
[NURBS Export]
WriteAnalyticCurves=n
WriteAnalyticSurfaces=n
So SAT file can only be exported when both parameters are set to "n"
2. One model for exports from Rhino and Moi to see difference in SAT files:
The Problem comes from MoI 3dm because:
If I create .3dm file in MoI - no matter where I export from to SAT (from Rhino or MoI) - export doesn't work properly.
If I create .3dm file in Rhino - no matter where I export from to SAT - export works just fine
Therefore I cannot give one .3dm model and 2 SAT files exported out of it, instead I have created identical shapes in both Rhino and MoI to be able to generate both bad and good SAT export
pls see attached (also import dialog - but nothing really changes there from import to import)
Sorry for this problem, hopefully you'll be able to fix it
Regards, Igor
Size: 60.1 KB, Downloaded: 30 times, Dimensions: 920x668px
