V2 beta Apr-12-2009 available now
2570.18 In reply to 2570.15
Thanks Danny! Yes that would be great to hear about how it feels in use.
Some basic quick tips and overview:
If you have a particular object you want to refer back to later on, you can give it a name and then it will show up under the Objects section. You can also assign the same name to several objects and then they will all be controlled by that one name entry.
If you want to do stuff that targets particular types of objects, like "Select all curves", "Hide all solids", things along those lines, then the Types section is where you want to go for those.
You can use Styles if you want to do organization by using colors, also I plan to make style assignments become material assignments in exported polygon files but that part is not quite ready yet.
So basic stuff right now is assign an object a name or a style and then you can manipulate it with the browser.
Then the way that the actions work, is that you can click on the eye to switch an item to be hidden or showing.
You can right-click on an eye to "isolate" that item which makes it the only shown thing and isolates all others. If you right-click on an isolated item it will un-isolate it and show everything.
You can click on the text part of an item to select it - left click selects it, ctrl+left click deselects it, right-click does an "isolate select" (makes it the only selected item), and ctrl+right-click does an "isolate deselect" (makes it the only deselected item, with everything else selected).
If you have a sequence of eyes that you want to all set on or off, you can hold the mouse button down and swipe over them.
Let's see what else - in Styles you can also click on the swatches to do some stuff - if you have a selection then left click on a swatch will assign the selection to that style (can also be done if the browser is hidden by the new Style entry in the properties panel), if you right click or left-click with no selection on the swatch it will set the active style to be that one. That's the one that will be used for drawing new objects it is the one that is marked with an outline around the outside of it.
If the text of an item is grayed out it means that there are not currently any objects that fall in that category.
EDITED: 12 Apr 2009 by MICHAEL GIBSON
