Hi Burr - there is not currently any way to edit the path, right now you would instead insert a new image with your updated path and delete the old one.
But if you just want to move the image into the same folder as the .3dm file, you can just do that without editing any paths. When MoI opens a file with background images, it will first look for the image with its full path and if it does not find it there it will also look in the same folder as the .3dm file and get it from there if it finds it.
It would probably be a good idea to have some method to edit the path though, I can put that on the wishlist. Do you have any idea what kind of UI to use for doing that? One thing is the options panel for Background images is pretty well filled up with stuff already.
