Hi scarabrae - most likely you have the new IE version 8 installed that was released just a week or so by Microsoft?
That version happens to have a bug in it which prevents MoI from showing the "Done" and "Cancel" buttons which are normally supposed to show up in the upper right options area.
Basically without those buttons showing up, the regular command flow is messed up and that has a side effect of the curve command behaving like you are describing.
At the moment you'll need to run MoI on a machine with IE7 or IE6 on it instead for it to work properly.
But I should be putting out a new patched version of MoI v1 pretty soon here which will avoid the problem though.
