Network and boolean diff problem, Mar 27 2009
2527.3 In reply to 2527.1
Hi Otterman - re: Network - the particular curves you used for trying the Network do not seem to be in that file...
But from the ones that were in there on the one side it looks like it is split up into a couple of different curves there:
You'll need to join those together - without them joined together Network will consider them to be 2 independent parts of the network and get confused when it is unable to determine the grid layout.
