Hi Peter - in order to blend between surfaces you need to select a surface edge.
You happen to have a closed curve object in the same location as the surface edge, probably some curves that were used to construct the surface?
Hide or delete those curves so that you can select the surface edges and then you will be able to make a blend between edges.
Let me know if you are still stuck.
