How could I carve windows in a semi-sperical solid?
2508.1
Hi Guys,
I am struggling with one thorny issue it this point. Could someone point me in the right direction?
I have punched windows in this shape, and my next step should be to blind each of them at a constant depth, ideally perpendicular to the curvature of the outer shell. It would be like milling notches in a solid.
I thought of using offset but it does not seem to work. I also thought of recycling the individual panels that I cut out, but they cannot easily be offset perpendicular to the surface. Maybe I could use Boolean difference, but I should first be able to give each panel a uniform thickness and sort of impress it into the solid. Conceptually, that sounds promising, but how to do that consistently?
Any thoughts?
Thanks in advance.
Jean-Paul
EDITED: 23 Mar 2009 by JPBWEB
Size: 121 KB, Downloaded: 33 times, Dimensions: 1280x990px
