delete
2479.5 In reply to 2479.1
One other thing that you can do to make this a little easier in v1 is to hide all the other objects than the current selection. That way after the export is done you can use Ctrl+A to select just those objects and delete them.
You can also use this command for a keyboard shortcut (Go to Options / Shortcut keys to add in a new one), which will hide all objects other than the current selection:
script:var gd = moi.geometryDatabase; gd.invertSelection(); gd.hide(true); gd.selectAll();
Paste the above in as the "Command" part for the new shortcut key.
