Hi Marcel, do you mean you want to write out only some of the objects in your model and not everything?
To do that, first select the objects that you wish to write, and then use File/Export.
The Export command is a shortened name for "Export selected" - it will write only the currently selected objects out to the file that you choose.
The regular "Save" or "Save As" commands will write everything regardless of selection.
