Scene browser progress
2470.90 In reply to 2470.89
Hi Rob, thanks for your feedback!
> will there be an option to isolate a group that can be worked
> on in isolation?
Yup, the idea is to do that with a right-click on the eye icon.
A left-click on an eye will just turn on or off that particular item, but a right click will hide everything else except that item, and a second right-click on it again later will turn all things back on again.
> What would be even better would be the greying out of the rest
> of the model which would become inactive but still there as a
> reference for guide lines etc. But maybe that might be a bridge
> too far just now.
That will be called "locking", and I do want to have that but it probably won't be in this next beta with the first round of this stuff in it.
> Will instances still be a V3 feature or are you on a roll?..............
Not on quite that much of a roll! ;) That's going to take quite a bit of work to make instances function well, so I don't think it will be possible to get that in for v2.
> EDIT: Also can I make a cheeky request for the exportation of
> groups/styles for poly models be put at the top of the priority
> list for the next beta - and can that beta just consist of that feature!!!
I sort of need to the UI nailed down first so that I know how things should behave in MoI. Once that behavior is worked out then after that I can figure out how to map the mechanisms in MoI to what is supported in a particular file format.
So probably the next beta won't have this part working yet, but it will be happening before v2 is finished for sure.
