Scene browser progress
2470.113 In reply to 2470.112
Hi Tony, yeah I'm going to be experimenting with a few things along those lines.
At the moment I have it set up so that the text is highlighted in blue for the row that your mouse is currently over.
I also tried darkening the whole row like you show there, but it felt a bit heavy handed. I think I'm going to try a kind of outline border around the row the mouse is over.
I'll also probably experiment to see if I can do a slightly different alternating color between rows which can help with this kind of alignment recognition.
> As an aside, I did notice that modo doesn't use the connector
> lines - and I can't say that I have missed them :-)
They're just basically the vertical equivalent of the same kind of horizontal alignment stuff that you are mentioning... They just help out a bit to more immediately see which things are siblings, even if there is a gap between them with child stuff popped out.
I don't want to draw a whole bunch of attention to them, so I made those dotted so they hopefully won't be too distracting.
