Scene browser progress
2470.106 In reply to 2470.103
Hi Michel,
> - Will it be possible to temporarily turn style colours off to
> have a more uniform preview of the shapes ?
This is something that I want to add in, but it probably won't make it in until v3.
I'd like to put a "display mode" type dropdown under the View palette on the side pane, that would let you switch between some different modes like "Standard", "Shiny blue", "Zebra", etc... Also probably a checkbox to temporarily turn off the display of edges.
> - And I like the active style square and the right click
> attribution process but, apart from looking at the shapes
> colours, is there a way to see what is the selected shape style
> while (still) seeing the "active" style that will be applied to
> the next shape ?
Yeah, the style of the current selection is available in a different location - in the object properties panel here:
Also a style picker will pop out from there if you click on that line, so that gives a way to assign a style to selected objects even if the browser is closed. But if the browser is open probably you'll want to click on the swatch to do it instead.
Right now the browser does not have anything within it that changes due to object selection (it updates when objects are created or hidden/shown), instead the object properties panel is the thing that updates in response to selection, at least for now.
