applejuice to apples reloaded ... : P
2469.5
There's a some stored wisdom about doing reverse-engineering with Rhino on their wiki:
http://en.wiki.mcneel.com/default.aspx/McNeel/ReverseEngineering.html
Specifically the Scan, Cleanup, Remodel whitepaper linked at the bottom is pretty good.
However, if you're coming from SubD, it's probably easier to convert the control cage directly to Nurbs rather than getting a subdivided model and doing reverse engineering. It'll be a lot faster, generally better looking, and your Nurbs will have the same isocurve flow as the original SubD.
There are a few programs that will let you do the conversion from the control cage directly to Nurbs. There's Maya, Catia's imagine and shape, and T-Splines for Rhino, that I'm aware of.
I'm a developer for T-Splines, so I'm a bit biased, but I think you'll get better output from any of those than from manually reverse engineering.
