I tested a little bit more - at angle 12 there is a big poly count jump between "avoid.." 0,92 and 0,93. If I set a smaller angle, than the problem appears at a lower "avoid.." value. Could be nice, if the issue could be solved, because the user can't know, when he riched the critical values.
Good luck,
Micha
