(9) rotation object
Once more ... I create a rotational object per Rhino and convert it per MOI - perfect, all polygons are quads. Than I add fillets to the source objects and convert it again, but now I got quads+triangles (should be possible without triangles or?). Interesting is, that the Rhino command _QuadrangulateMesh can be used to eliminate some triangles. I have the feeling, if _QuadrangulateMesh works, than the mesher created to much triangles, more than necessary.
(10) torus
Here it could be nice, if polygons around the torus profil could be in the same angle. At the moment the inner polygons are finer than expected. This could be interesting for using the mesh per T-Spline or Sub-D modeller.
