| Hi Burr,
 > Wouldnt the avoid smaller than option fix this? or is
 > that in the other direction.
 It can help to reduce subdivisions, but more often on a more regular density mesh than one that is already being generated at a very coarse angle.
 Basically the "Avoid smaller than" takes a distance, and any polygon that is smaller than that distance will instead shift to use a coarse angle of like 35 degrees rather than the regular angle.
 This makes it possible for something like a tiny curved fillet in your model to get meshed at 35 degrees rather than say 5 degrees for everything else.
 But if you are already doing everything at 50 degrees then it won't make any difference.
