system decimal display
2445.6 In reply to 2445.1
Hi Burr - one other question - in your screenshot there you had all values less than 1, is that normal for the kind of thing that you want to get the higher level of display precision on?
I can probably do a better default job with that range of numbers, since when there is only one digit on the left side of the decimal it means the number will still be fairly compact overall even with more digits to the right of the decimal.
I mean like 0.2534 is quite a bit easier for me to fit there than something like 1952.2534 where there are more digits to the left as well.
