Hi Schbeurd - Michel has the right answer - the path as generated uses the AI "n" operator for those paths which means to not output any graphics for it, neither any kind of fill nor stroke.
If you load it into Adobe Illustrator, the paths in that file will not render anything on the screen, until you select it and assign it some kind of render property like any line thickness or a fill.
Actually MoI version 1.0 will still read that path - for MoI v2 I changed the AI importer to skip these unrendered paths because sometimes there can be a whole bunch of unwanted extra junk that is set up with them, like sometimes duplicate paths, unwanted frames around pieces, things like that.
Maybe what would be a good compromise though would be to try to make one pass through the file with skipping those unrendered paths, but if nothing at all was found then I can make another pass through and include them...
