Problem with AI import
2443.19 In reply to 2443.18
Hi Michel, this was a bug in MoI's path processing, when handling the special "re" (rectangle) operator when the width or height of the rectangle was specified as a negative value.
It looks like Illustrator just happens to generate rectangles with a negative width value, while Photoshop generates them with a positive width value, which is why the Photoshop ones avoided the bug in MoI.
I have fixed this up for the next v2 beta, so that the rectangles generated by Illustrator will be handled properly now.
I think it should also be possible to avoid the problem in the current beta if you export using the older version AI format, like version 8 or earlier. Those older file formats were before they switched to the PDF style format and the old style files do not have a "re" operator, instead they will just contain 4 lines to make a rectangle so those should work.
Thanks for posting the example file and the additional information!
