Line creation
2413.3 In reply to 2413.1
Hi Rob, I missed this part:
> Also having a loop or auto edge connect feature: Say I have
> extruded a shape and I want to then extrude it some more
> at a later date, currently I select each edge of that shape and
> then extrude again. Could there be a way to have the edges
> conected by default and if selected the separate command
> could be used if only one or more edges were required?
I'm not sure if I'm following this correctly, but if you want to change the extrusion height of something that you have already created, I do want to make that possible in the future by being able to edit some of the history of how the object was created. Currently in MoI there isn't a way to edit that particular type of thing, you can only edit input objects like the curve. But I do want to provide a way to edit these other kinds of values like a height later on, hopefully in v3.
You may be able to use the Transform / Scale / Scale1D command currently to change the height of something in just one direction, that may work for adjusting an extrusion height for now.
Sorry, I'm not quite sure what you are describing about having the edges connected by default... Maybe you mean have them grouped to select together? I think something along those lines will end up being possible with some grouping work that still has yet to be finished for v2, we'll see how that goes.
