Line creation
2413.1
Ok here goes another request/suggestion! For all Archicads issues it does have a good system for drawing lines.
When you click to draw a connected line you get a little pet pallet that pops up near your mouse which lets you switch between straight and curved lines on the fly as it were which makes for speedy drafting. Also it has a good curve feature that automatically creates a smooth circular blend from one line to the next which really helps to get smooth tangents.
Also is it possible or will it be possible to adjust tangents (handels) as well as just moving a lines points?
Last question but more layer related. Im assuming different layers will have different colours but will it be possible to adjust the transparency of a layer - say for glazing?
EDIT: Can I bolt on another request for a camera that rotates around the camera axis - like standing still and looking round. It makes it easier to view internal spaces, which im finding a bit of a nightmare just now!
Also having a loop or auto edge connect feature: Say I have extruded a shape and I want to then extrude it some more at a later date, currently I select each edge of that shape and then extrude again. Could there be a way to have the edges conected by default and if selected the separate command could be used if only one or more edges were required?
Rob
EDITED: 16 Feb 2009 by RHODESY
