chamfer on lines?
2402.9 In reply to 2402.8
Hi rhodesy,
> I don't suppose there is a way to override the moi acuracy
> for calculation to take this into effect?
There isn't currently any way to override the accuracy level, but I do have some plans to try and make the accuracy more adaptive to the size of the model rather than fixed at one specific size. There are a couple of things that do this in v2 so far such as Join and Network. As time goes on I want to tune up more things to work in a similar way but it can tend to be a somewhat delicate area to mess around with.
> Just tried converting the model into cm and it works a treat -
> much faster and the file is down to 29mb.
What will probably happen also is that your file size shouldn't grow quite as quickly when you do some additional operations at the somewhat smaller size level, like booleans, etc... since those will generate less dense intersection curves.
I'm actually kind of surprised that it made much of difference right away.
> I like the way moi automatically scales your whole scene for
> you - would be cool to be able to scale the background images
> at the same time.
Oops, that is definitely an omission there! Yeah that would definitely be better for those to scale along with objects. I should be able to fix it up to do that in the next v2 beta. By the way you can disable the scaling if you wish by going to Options / General / Unit options / Scale on unit system change checkbox.
EDITED: 15 Feb 2009 by MICHAEL GIBSON
