Saving + placing camera views?
2396.4 In reply to 2396.3
Hi rhodesy, maybe I misunderstood what you are asking for with the planar sections stuff - are you asking for what is sometimes called a "clipping plane" where it basically temporarily hides a chunk of your model from view rather than generating curve or surface data?
When you mentioned for modeling purposes I had thought you meant generating model data...
> It would be nice to have a way to twist or re-orientate
> the camera whilst looking at the same point if you see
> what i mean?
Yup, actually that is what should be happening already with placing the target point with that "Zoom area" tool.
Here's a quick screencap:
In the example above, I placed the target point of the view directly on to the corner of that box by using Zoom Area. Then notice how when I rotate the view after that, it is always looking directly at that same point (that same corner of the box)... Is that what you are looking for?
I guess if you are seeing something a lot different than that, I may need some more description or illustration to understand, sorry!
