problem filleting a planar surface
2388.2 In reply to 2388.1
Hi Jonzker, it looks like one of the previous fillets didn't do a completely proper job and left a little gap in the object.
One clue for this is with version 2.0 the "object type" readout in the upper-right corner of the window says that this object is a "Joined srf" rather than a "Solid" :
The problem seems to be along this edge here:
This object may need a bit of surgery in that area to repair it first before that fillet you want to do will work, I'll take a look to see if I can tune up this object.
