Hi PaQ - I'd need to add an additional center grip for that to work, so that there was something that you would hit with the mouse to initiate the drag.
I've been hesitant to do that because one big goal of these object frame grips is to have a very low level of distraction and interference with other operations. Having them really low profile helps to make it possible to have them enabled all the time and always available.
One part of that is how they normally go all around the outside of your selected object rather than overlapping into it, and having a center point grip would go against this...
Anyway, that is why I have stayed away from that so far.
Maybe I should try to do one that was slightly different than the other grips and make it totally invisible until you moved next to it, rather than translucent... That would help to avoid visual interference at least.
