Autodesk InventorFusion goes Public
2378.5 In reply to 2378.3
> Is this a direction moi could take further down the line?
> Or does that sort of flexiblity need to be designed in from
> the start?
I do expect to add more stuff in MoI for editing the history of how you created an object, but that is kind of a different thing than the "direct modeling" mechanism used in SpaceClaim.
That direct modeling stuff kind of requires a lot of fairly specialized code for analyzing and categorizing shapes. It's not so much about just planning for it, it is just a lot of work to make stuff like feature recognition function well.
> wish they did just a payfor and download cut-down version
> for general modelling
Yeah, as you found they actually have this now with their LTX version.
They focus on marketing that version as a companion to Rhino but I doubt that it requires Rhino to actually run, and since MoI uses the same 3DM file format as Rhino I would think it should work with MoI as well.
I'd suggest asking the Novedge people to make sure: info@novedge.com
Or also post a question in the forums here: http://www.spaceclaiming.com/
