MoI Shortcuts Closed
2364.12 In reply to 2364.11
Hooo sorry then, I see the problem a little bit better ;)
For sure scripts are a problem, it's somehow, "hidden functions that you have to map yourself to run them".
I can imagine it's quite hard to learn them all, or assign a shortcut for every extra scipts around.
I think it would be helpfull to have
- a script launcher function (F6 in modo), where a popup window open and let you select and execute a script from your HD ... handy for some scipts that are used once a month.
- some place should be found in the interface (that's not easy ^^) where all the extra command installed are listed, with their own button, so you don't have to remember any shortcut.
Should be quite low in priority list I suppose o)
