Screen capture
2341.9 In reply to 2341.1
Hi Schbeurd, re: numeric palette going out of the window in screen captures -
In the next v2 beta there will be a new moi.ini switch that you can set:
[UI]
KeepFlyoutsInsideWindow=n
The default is =n which is the same as the current behavior. If you switch it to =y then it will keep those flyouts to be contained within the main window boundary which should help for that screencapture case that you mentioned.
But like Tony mentions, a pretty easy method to make it work now is to move the window to be near the edge of the monitor which will have a similar effect now.
