Hi Bernard, haven't seen you here in the forum for quite a while! Hope things are going well with you.
It should be pretty easy for me to add in a moi.ini switch to force flyouts to stay inside the window similar to how they stay inside the full screen.
I probably won't want to set that by default, because normally I would consider that situation with the flyout kind of hanging partway off the window to actually be a good thing because less of the main window is being hidden by the flyout...
But it should be quite easy to add as an optional thing to turn on.
I'll give it a try when I return from vacation, I will be away for the next week.
