Twisted Loft
2337.2 In reply to 2337.1
Hi Duke, it looks like your bottom profile curve is not fully closed, that is what is confusing the thing that tries to automatically align profiles to reduce twist.
The open part is here:
Zooming in close to that circled area:
I've attached a tuned up version here as KMTower_02.3dm - with that bottom curve closed it should then do a proper job of untwisting the Loft for you automatically.
One quick way to tell if a particular curve is open or closed is this new object properties readout in the last couple of v2 betas:
That will say "Closed Crv" there if you've got a closed curve, if it says just plain "Curve" then that means the selected object is an open curve. That's what I used to quickly check if all the curves were open or closed in this case.
Hope this helps!
